Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Primary Cover torque/bolt sizes
Old 09-18-2006, 01:01 AM
gconklin's Avatar
gconklin
gconklin is offline
Default Primary Cover torque/bolt sizes
I must be blind but I can't find the instructions for installing the Primary Case Cover in my HD service manual. Different sections refer to other sections for those instructions but they all end up in a section that doesn't go that far in the process... stops at installing clutch and doesn't continue. I searched for the answer in previous posts but only found Scout's post which gave great detail but I wasn't sure it is the same for my bike.
So I'm trying to figure out what the torque settings for my '94 heritage. Joe said 8 ft/lbs. If you know what page their on in the manual, I'd love to know that as well. Also, what allen wrench size are the bolts and torque screws for the inspection cover?
Thanks for any help!
Old 09-18-2006, 10:10 AM
glide's Avatar
glide
glide is offline
Default RE: Primary Cover torque/bolt sizes
The bolt size should be a T27 for the cover and the torque specs should be on the first page of the manual for that section (usually 9-10 foot LBS). They list all the torque specs for each section in the beginning of that section and not in the text itself usually. There are exceptions in some sections.
Old 09-18-2006, 11:17 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
delete!
Old 09-18-2006, 12:11 PM
gconklin's Avatar
gconklin
gconklin is offline
ORIGINAL: glide
I appreciate the info, guys!
Hmmm, I thought I looked at every word, every figure, every table. Disassembly is there, but the assembly section just says "See so-and-so section". So I go there and it says "See this-and-that section". I go there and another "see..." comment. The last one I get sent to doesn't even state it though. But I'll go look again, for the 10th time and see if your posts were key to opening my eyes,
Old 09-18-2006, 09:34 PM
gconklin's Avatar
gconklin
gconklin is offline
ORIGINAL: 1FLTRI4ME
delete!
why was this deleted?
Old 09-18-2006, 10:25 PM
1flhtk4me's Avatar
1flhtk4me
I misread your post.Thought you were asking about the primary chaincase cover.
Old 09-19-2006, 12:35 PM
gconklin's Avatar
gconklin
gconklin is offline
ORIGINAL: 1FLTRI4ME
I was... unless I got the names all wrong. The large chrome cover going from my shifter to rear wheel. Isn't that the Primary Chaincase Cover? (though I did shorten the name to Primary Case Cover)
Sorry to confuse y'all. :S
Old 09-20-2006, 10:27 AM
1flhtk4me's Avatar
1flhtk4me
ORIGINAL: gconklin
It is called the clutch inspection cover.
Old 09-20-2006, 12:29 PM
gconklin's Avatar
gconklin
gconklin is offline
ORIGINAL: 1FLTRI4ME
ORIGINAL: gconklin
What I'm referring to is the cover that the Chain Inspection Cover and the Clutch Inspection Cover are bolted onto. Isn't that the Primary Chaincase Cover?
(sorry to be so confused)
Old 09-20-2006, 04:08 PM
glide's Avatar
glide
glide is offline
ORIGINAL: gconklin
Yes, that is called the primary chain case cover, primary cover and a few others too.
Quick Reply: Primary Cover torque/bolt sizes
