Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Tools for Changing Oil, Primary, and Tranny Fluids?
Old 07-08-2005, 02:52 PM
MB's Avatar
MB
MB is offline
Default Tools for Changing Oil, Primary, and Tranny Fluids?
Hi guys, planning to do my own servicing for above fluids. Purchased the oil filter fitting at dealership last night, but was wondering what type of sockets etc are needed to appropriately remove & tighten (to correct in/lbs or ft/lbs). I have a few tools, but think am going to have to buy some more. Any recommendations on tools that will be needed would be great.
Additionally, would you guys help me verify where all 3 drain holes are. Believe have located the primary drain, but definately confused where the location of tranny drain is along with oil (even after looking at my $58 service manual).. Again, much thanks for helping a new guy. mb
Old 07-08-2005, 03:52 PM
John TN's Avatar
John TN
John TN is offline
Big Kahuna HDF Member
Default RE: Tools for Changing Oil, Primary, and Tranny Fluids?
Not sure what model Harley you have, the oil filter removal is done with a slotted finger cap type wrench, available at your harley dealer, you reinstall by hand. The drain plug for the primary is torx head, and I use liquid teflon to help seal it, it's a pipe type thread. The engine oil and trans plugs are allen headed in the center of the nut head bolts they are straight across from each other if you have a tour model, I usually replace the o-rings if they look torn at all, and I use liquid teflon on these as well.
John TN
JMilligan (04-19-2020)
Old 07-08-2005, 03:58 PM
rpoteau's Avatar
rpoteau
rpoteau is offline
MB,
I know for the primary derby cover you most likely will need some torx wrenches I believe these have similar heads to allen but slighty different. I know on my sportster the drain line is a rubber hose near the kickstand that you remove the plug from to drain. It confused me when I went to do it the first time b/c I was so used to cars with a drain on the oilpan. Not sure what model you have but on my sportster the practice is to drain the oil tank from the hose and then take the filter off the front to drain the excess. I would just tighten the oil filter by hand and not try to torque it down as you could do some damage if you really have to struggle to take it off. Perhaps someone with your model bike could give you the exact locations of the primary/tranny drains. Are you riding a deluxe. I saw from your previous posts that you are asking questions regarding one. If so, what year? I know a few knowledgable folks such as TCSTD have a deluxe and should be able to help you.
Good luck
-Ryan
Old 07-08-2005, 04:16 PM
oldgeezer's Avatar
oldgeezer
oldgeezer is offline
If you have a Softail...
The transmission drain is up between the shocks. I'd suggest using a socket to do the initial half a turn or so, then use an allen wrench. The factory cinches up the plugs pretty tight and there is a risk of stripping the allen head in the plug. The plug is either 5/8" or 3/4" hex head, can't remember which. The transmission fill plug is 3/8" allen.
The drain plug for the crankcase is on the high side of the bike in the frame just by the shocks. Same plug as the transmission.
The primary is an allen bolt on the bottom of the outer primary case.
I'd suggest you get an service manual from the Harley shop. It is the best $50 you can spend there.
Old 07-08-2005, 05:07 PM
John TN's Avatar
John TN
John TN is offline
ORIGINAL: oldgeezer
Geezer I think he's got one already. Good advice for sure.
Old 07-08-2005, 11:41 PM
billnourse's Avatar
billnourse
billnourse is offline
Without knowing what bike you have, it's hard to give you reliable information. Here's the best I can do.
If you have an 80 inch EVO, the drain plugs are 3/4 inch, and the primary will be torx.
If you have an 88 inch, the oil and trans. plugs will be 5/8 inch with an allen center. As Geezer said, use the socket to loosen the plug, then use the allen to remove it.
If you have a softail, the oil plug is in the frame just under the oil tank on the right side. The trans plug is between the rear shocks.
If you have a touring model or Dyna, the oil drain and the trans drain are both in a pan under the transmission. The plug that faces down is the transmission, and the plug that comes out the front horizionally is the oil.
The derby cover is torx, and the primary drain is either a torx or allen. I think I found on my dresser that the drain plug was an allen. I've only changed it once so I'm not sure. Seems I remember thinking it strange that the drain was allen and the derby was torx.
Hope this helps.
Regards,
Bill
Old 07-10-2005, 04:30 AM
ClassicRider2002's Avatar
ClassicRider2002
ClassicRider2002 is offline
We really need to know what bike you own???????
For an EVO 1999 FXR2 and the outer primary is also for a 2002 RKC
Primary Chain case
1) Outer Primary Cover
A) 10 Allen Head Bolts 3/16”
B) Torque Sequence Is hopefully attached as a jpg file
C) Torque Value 84 - 108 Inch Lbs 7.0 - 9.0 Ft Lbs
D) Gasket Replacement OEM# 34901-94
E) Pages 1-27
2) Primary Chain Inspection Cover
A) 4 Torx Bolts T-27
B) Torque Sequence Alternating
D) Gasket Replacement OEM# 34906-85B
E) Pages 1-27
F) Shifter Arm Allen Bolt 3/16”
Torque Value 18 - 22 Ft Lbs
Pages 7-3, 7- 32
3) Clutch Inspection Cover (Round Derby Cover)
A) 5 Torx Bolts T-27
B) Torque Sequence See Above
D) O~Ring OEM # 25416-99
E) Pages 1-28
4) Magnetic Drain Plug
A) T-40 Torx
B) Teflon Tape 565 To Thread
C) Torque Value ~~~> Don’t Over Tighten
D) Pages 1-28
5) Lubrication
A) Primary Oil
B) Amount:
1) 32 oz
2) 26 oz pg 1-28
3) 38-44 oz Pages 2-1, 6-1, 6-24
C) Input Oil Through The Clutch Inspection Cover (Round Derby Cover)
D) Recommended To Be Done Every 5,000 Miles
I Will Do Mine Every 2,500 Miles
E) Pages 1-29
6) Primary Chain Adjustment
A) Recommended To Be Done Every 5,000 Miles. I Will Do Mine Every 2,500 Miles
B) Pages 6-7
7) Clutch Adjustment
B) Pages 1-29
OIL
A) Oil Filter
1) Micron Synthetic Media Oil Filter
2) OEM# 63798-99 Chrome
3) OEM# Black’
Lubricate Oil Filter Before Installing
B) Drain Through Hose
C) Capacity
3 quarts capacity page 2-1
3 quarts install <~~~when doing an oil change put in a full 3 quarts
After you get 2.5 quarts in start engine for a moment….
Which means Oil must be YOUR last fluid you install
E) 20-50 Red Line Synthetic
F) Page 1-25, 2-1, 1-26
G) Change Every 2,500 miles
TRANSMISSION
A) Transmission Lubricant Drain Plug 7/8” Nut W/ Nylon Washer OEM #6007
1) Torque Value 168 - 180 Inch Lbs 14 - 15 Ft Lbs
B) Transmission Filler Plug/Dipstick Located In Clutch Release Cover 3/8” Allen Head Bolt
1) Torque Value 25 - 75 Inch Lbs 6 Ft Lbs
2) O~Ring For Dipstick OEM # 11132
C) Fill To 20 - 24 oz Put In 22 Oz
D) Motorcycle Level Upright Position With Filler Plug Resting On The Threads
E) Red Line Shockproof Gear Oil
G) Pages 1-30, 7-3, 7-19
FOR A DYNA LowRider 2003 TWIN CAM ENGINE.... of course the capacity for a touring bike vs a non touring bike is a difference of 1 quart of oil with the touring bike's capacity being 4 quarts.
Primary Chain case
A) 12 Allen Head Bolts 3/16”
B) Torque Sequence Is Above
C) Torque Value 108 - 120 Inch Lbs 9.0 - 10.0 Ft Lbs
D) Gasket Replacement OEM# 60539-94A
E) Pages 6-2, 6-3
D) Gasket Replacement OEM# 60567-90B
E) Pages 1-24, 1-25, 6-2, 6-3
Old 07-11-2005, 02:46 PM
MB's Avatar
MB
MB is offline
Sorry for delay guys, wasn't near a computer all weekend. I have an 05' softail deluxe. thanks again for all your help. mb
Old 06-15-2006, 07:00 PM
cutacroshorty's Avatar
cutacroshorty
cutacroshorty is offline
I sure would like to have all of that information for my '03 Ultra Classic FLHT.
Old 08-21-2007, 05:33 PM
my2dogs's Avatar
my2dogs
my2dogs is offline
hey guys, I am brand new been here a while just lookin around, just did the oil on my super glide, filter is a pain in the neck, gotta go tomorrow and get one of those special filter tools, just wanted to say thanks to all for the help. I have a 2004 dyna I just picked up, only has 700 miles and wanted to get all the old oil out, it sat around for some time. time to say bye to my sporty, this dyna is the nuts I love it!!![&:]
Quick Reply: Tools for Changing Oil, Primary, and Tranny Fluids?
