Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
adjusting clutch cable on 08 nightster
Old 03-17-2012, 06:35 PM
lahie's Avatar
lahie
lahie is offline
Stage II
Cool adjusting clutch cable on 08 nightster
can i get some info on adjusting clutch cable
Old 03-23-2012, 08:23 PM
Navychief's Avatar
Navychief
Navychief is offline
Follow the clutch cable to the rubber boot (should be clamped to the left down tube), and push the boot down the cable til the adjuster is visible. Loosen the jam nut and tighten or loosen the adjuster until you have 1/16 - 1/8 inch free play in the lever. Tighten the jam nut, remove any corrosion on the adjuster and spray a little WD40 on it. Slide the boot back up and ride.
gilbert_roadking
11-15-2016 06:21 PM
keith t
06-29-2016 10:43 AM
Gonzy
06-22-2012 07:39 AM
GEESE
08-11-2009 08:05 AM
hdchopperman
03-23-2006 09:18 PM
Quick Reply: adjusting clutch cable on 08 nightster
