Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
I can buy a DD6 from a crashed softail, i know the primary chain is to long, but is there any other differnces like top drum, main shaft, speedo that that would prevent me from doing this. i know I should just call Baker, but thought I'd ask here.
The trap door is different, it has an ear for the exhaust bracket which will interfere with your oil spout. I can get you the right one or you can cut it off. Heads up if you decide to cut it off remember that it is chrome and the chrome may peel off.
mark would I be able to use my trap door without any machining.. also he has the 28 tooth compensator, but I expect the chain will be a different length, if so I'll need one for a 03 road king setup.
There is no way to make the door work without removing the ear the oil spout is in the way. You will need a 78 pitch chain to go along with the 28 tooth comp sprocket.
