Shift lever slipped off the trany (TURQUE?)
Shift lever slipped off the trany , I have it off and inspecting the spline on the trany and lever .. Both look fine . It appears the Allan head bolt had backed off just enuf for the lever to slide off. I'm headed to the auto parts for a new bolt and red loctite .. My question is , what do I torque the bolt down to ? I can just see me giving it hell and the head pops off . I know I should have a service manual !
Thanks
Thanks
Get a grade 8 bolt. Get it tight. Some guys hacksaw the space where the lever is pulled together by the bolt (put it in a vise and squeeze it until the space is closed and then hacksaw it, which makes the space a little bigger, allowing the bolt to pull it tighter on the shaft (I hope that makes sense).
Dan89 Yes that makes good sense , I have not found the bolt just yet , I live in a small town so I'll be going to the city today ! the bolt is an odd size, M8 1.0 pitch all I can find around here is M8 1.25 pitch.. while in the city I'm going to buy a new lever at the Dealer so I will Have the old one to do what you recommend .. Thanks for the tip , I bet thats going to work great
