stripped shift lever retaining bolt
Old Apr 5, 2008 | 01:24 PM
rnl_1200C's Avatar
rnl_1200C
Default stripped shift lever retaining bolt
I was looking to adjust the shift lever height, but the shift lever retaining bolt head is stripped.
Any suggestions on how to fix this and get it out ?
Thanks.
Old Apr 5, 2008 | 02:06 PM
Tommo's Avatar
Tommo
Default RE: stripped shift lever retaining bolt
Can you get some pipe grips on It?....or use a small hacksaw or a file and put some flats on the sides to use an adjustable wrench on It...or...use some W.D 40 on It,hacksaw a slot In the top to use a screwdriver on It....or...without going to look at mine,as a last resort...can you use a hacksaw blade through the slot in the lever to cut the bolt in half,take the lever off,drill a hole through the remaining threaded bolt and use an easyout to screw It out.
Old Apr 5, 2008 | 08:29 PM
RATROD HOG's Avatar
RATROD HOG
is this one on the lever attranny shaft?
if this is the one's at hiem joints ,just drill only head off very easy with correct size drill bit
any ? please post back and i'll try to help more
Old Apr 6, 2008 | 09:46 PM
rnl_1200C's Avatar
rnl_1200C
ratrod - no, this is the one at the shift lever, at the footpeg - thanks
Old Apr 6, 2008 | 09:55 PM
cHarley's Avatar
cHarley
You might try to drive a 1 size too large torx bit into the bolt head. If that doesn't work, I'd get an ez-out.
apetterez
Apr 20, 2020 04:04 PM
apetterez
Feb 14, 2015 07:00 PM
Ernest T
Apr 9, 2013 07:44 AM
Carpe Noctum
Dec 3, 2012 07:52 PM
schoolmaster
EVO
19
Aug 20, 2010 02:20 PM
