Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Have an 05 1200C. Up shifting into 3rd gear; pulling clutch and upkick not getting anything or feeling anything until 2nd or 3rd up kick. Now starting to do it in 4th gear. Any suggestions on issues or clutch linkage adjustment possible? Any ideas would be great!
Never dealt with an 05 or any sporty past 03. Linkage would be the first check after that it gets kinda tuff. The gear set is inside the motor case and the case has to be split. Check the shift lever it self too and make sure it is tight.
