Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
compensator sprocket
Old 07-02-2013, 06:24 PM
maddghost's Avatar
maddghost
maddghost is offline
Default compensator sprocket
Hi ,
I have a decent build, shown in my sig, I found my clutch was slipping so I added a Barnett HD spring, now that that is good, I was hearing this clang noise coming from the compensator area. I had it all apart today, found red stator plastic stuff from last year when I let HD change mine out (big mistake) in there cleaned it out, torqued to max spec ( 165 lbft). if the clanging continues, can there be something wrong with the compensator? The bike has 52k miles and I don't baby her one bit. Would the screaming eagle compensator be a good move, do I even need a new one?
Old 07-03-2013, 07:37 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
What year bike?
Old 07-03-2013, 09:17 AM
maddghost's Avatar
maddghost
'08 fatbob
Old 07-03-2013, 08:22 PM
fastglass's Avatar
fastglass
fastglass is offline
Sounds like the compensator is bad.
Old 07-04-2013, 07:22 PM
prs4guitars's Avatar
prs4guitars
prs4guitars is offline
1st Gear
Sounds like a compensator to me.
Old 07-04-2013, 10:51 PM
ulltragliderider's Avatar
ulltragliderider
ulltragliderider is offline
The dealer just replaced my compensator with the SE part at 41k. Mine was making noise at start up and rattling when easing out the clutch from a stop. Noises are all gone and motor is noticeably smoother. The stock unit apparently is no longer available. The SE part is the way to go from my experience .
Old 07-05-2013, 09:39 AM
maddghost's Avatar
maddghost
I was on the phone with the dealer yesterday stock part is still available and about 100$ cheaper than the SE version. But why would anyone with a motor build would replace a failing unit with the same part is beyond me.
So Screaming Eagle it is! The thing is.... now that I have cleaned it - threadlocked it and re-torqued the comp bolt, it's no=longer doing it. I feel better now though knowing what it is and at least if I hear it again I can just get the piece and change it out!
Thank you all for the replies.
SavageChopper
07-31-2019 07:58 PM
Hocus-Pocus
06-08-2015 09:44 PM
Hazzardousmat
05-03-2015 11:35 AM
maddghost
07-04-2013 04:41 PM
Kim'sOldMan
09-01-2010 12:32 PM
Quick Reply: compensator sprocket
