Road King Clutch Trouble
Hi,I have a 2001 FLHR,I had to replace the tranny sprocket last week everything went smoothly,didn't change any adjustments except maybe a turn or 2 on the clutch adjuster.After replacing the tranny sprocket it all went back together as smoothly as it came apart.I added oil started it up and put in gear it wanted to take right off,so I removed the clutch cover and pulled the lever in and out and could see the clutch disc's moving but weather the clutch lever is in or out it does not disengage any idea's 'cause I'm fresh out? I'd rather not take it to the dealer,there has to be a simple explanation...
Thanks up front,Mikey
UglyLou
06-25-2008 03:46 PM
