Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
I have run into a problem trying to replace my shifter seal on my 99 ultra classic. I cannot get the primary case separated from the engine and transmission. Does anyone have any suggestions on how to remove it or if I need to remove it at all.
I have all the bolts out and also have removed the jack shaft. I have tried hitting it and some of it is loose but the area that I can't reach with the mallet is the part that is stuck. Any ideas how to break that seal where I can't get the mallet.
