Help! Stuck starter bolt
Old Jul 7, 2017 | 06:28 AM
blackxpress's Avatar
blackxpress
Default Help! Stuck starter bolt
Last night I was removing the inner and outer primary on my 2011 Road Glide Ultra when one of the starter bolts stripped out. It's nearly impossible to get to it with an ez out or anything like that. It's a 1/4 hex head bolt. I was thinking of trying to tap a torx bit in there but wonder if it might be possible to just remove the inner primary with the starter still attached. That way I could most likely get it out with vice grips. Can anybody think of a reason the inner primary would not come off with the starter still attached?
Old Jul 7, 2017 | 06:58 AM
MURPHCC1's Avatar
MURPHCC1
Nope......just remove all the wires on the back of it and it should come out with the primary......
IF it's like the 07 set up!!
Old Jul 7, 2017 | 06:39 PM
big- mike's Avatar
big- mike
Yep that should work
Old Jul 7, 2017 | 07:33 PM
blackxpress
Actually it didn't work. Not enough clearance without removing the final drive. I ended up buying a sacrificial torx bit, beat it in there with a hammer and the bolt broke loose no problem.
Old Jul 7, 2017 | 07:45 PM
MURPHCC1's Avatar
MURPHCC1
Good to know.....sorry ya had to go through that.......thought it would go with out a hitch!
Old Jul 7, 2017 | 08:17 PM
blackxpress
No biggie. All in all it was probably easier the way I did it. And, I learned a valuable lesson about working on my Harley. Next time I have to remove the primary it'll be a cake walk. The whole adventure began with a stripped out shift lever. Leave it to HD to make such a minor problem into a major ordeal.
Old Jul 7, 2017 | 09:25 PM
checkers's Avatar
checkers
Rapping directly on stubborn bolts will allow them to loosen easier, before it's stripped. Works on all bolts like the primary cover etc.
Old Apr 6, 2020 | 07:57 PM
harley rkc's Avatar
harley rkc
Stage I
Default Stripped Allen head starter bolt
Tap a stripped nut extractor over the edges.
Old Apr 6, 2020 | 08:03 PM
Zerk's Avatar
Zerk
Accoring to the guy who started the thread, and some pics I have seen at parts counter, show they are hex, and not allen anymore. Though the ones I bought last fall were still allen. good practice to replace if starting to look funny, if you can.
1981 suprglide
Shovelhead
Mar 20, 2019 10:14 AM
wharfcreek
Jan 14, 2019 02:57 PM
g-rat
Shovelhead
Aug 9, 2012 06:49 PM
JustDave71
May 26, 2010 12:54 PM
softailray
Sep 4, 2007 12:55 PM
