What is this Chirping sound??
Hi to all,
Stats:
2003 Road King w/5500 miles. Has a chirping sound at idle and low rpms. listen here -
Don't believe it is the lifters. Sounds like it is from the exhaust. More of a pulse characteristics when the noise bouces off a object. Hence worse when on concrete.
I have also checked all rubber mounts. (I think)
Any ideas??
Thanks,
Stats:
Any ideas??
Thanks,
And if the Y-pipe is cracked you can switch to a dual exhaust with either of these kits --
B&E Performance True Dual -- http://www.superflowmufflers.com/shopping.htm
Fullsac True Duals -- http://www.fullsac.com/true-dual-kits.html
Completely eliminates the Y-pipe so you'll never have a cracked pipe again :-)
