Hydraulics???
Sounds like it is bleeding pressure off in the master cylinder.
A mechanical cable clutch has no fluid or hydraulic action. The first place I would check for a problem would be the clutch actuator cover. This is the cover on the right side of the bike where your cable goes in. Couple things to look for, make sure the cable is securely attached and not fraying at the end. Second the cable is attached to a coupling which in turn is attached to your inner ramp. Below the inner ramp are 3 ball bearings and the outer ramp. This ball and ramp assembly is held in by a retaining ring. Make sure all these components are in place. If the snap ring is in place remove it and lift up the inner ramp. There will be pockets wear the three ***** ride in the ramps, make sure the 3 ***** are in their respective pockets. If they are not put a dab of axle or similar grease in each pocket and inspect and replace the ***** into the pockets and reassemble. Once you get that far report back and I'll explain clutch adjustment.
Hydraulic Clutch Woes
Is there any way to retro a cable clutch on a 2014 Electra Glide Police? I hate the factory hydraulic clutch. Every motor officer I know who has one hates it also. There is no friction zone. It's either engaged or not engaged. Engagement occurs far from the grip so the fingers have little control.
I see no reason why not, just get a 2013 mechanical side cover(clutch actuator cover the one on the right side), a ball and ramp assembly for the cover, new cable, clutch push rod, right side throw out rod and bearing assembly, adjuster screw and release plate. You will need a snap ring for the ball and ramp assembly as well. I know it seems like a lot but it can be done just a lot of small parts to gather.
