Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Whine and Rattle from Trans on FLHRS
Old 07-29-2014, 08:32 PM
Jabrnet's Avatar
Jabrnet
Jabrnet is offline
Stage IV
Default Whine and Rattle from Trans on FLHRS
So I have an 07 FLHRS and while driving home tonight, downshifted to first gear and all of a sudden a whine and rattle sound started.Sounds like it's coming from the Transmission.. . I raised the bike and tried shifting through the gears and it does it in all the gears but doesn't do it in Neutral. The bike has been shop maintained and up to date on service... a little over 19000 kms on it. this isn't a slight whine and rattle, this is something bad sounding. . Any suggestions? I did do a search and saw stuff about a minor whine but this is not sounding like they suggest.
Thanks for any help you can give!
Old 07-29-2014, 09:40 PM
dawg's Avatar
dawg
dawg is offline
Received 2,965 Likes on 1,715 Posts
Bearing probably. IPB maybe or if you are certain it's coming from tranny, then bearing there.
Old 07-30-2014, 10:41 PM
Jabrnet's Avatar
Jabrnet
Jabrnet is offline
Stage IV
Upon further investigation it appears the noise is coming from the main case... The chain and tensioner look OK... I'm not liking where this is going.
Old 07-30-2014, 11:07 PM
woodman's Avatar
woodman
woodman is offline
Check your compensator. It might have worked loose.
Is the noise from the front of the primary?
Take the cover off and look.
Old 07-30-2014, 11:10 PM
woodman's Avatar
woodman
woodman is offline
Do you feel a thump on the case just above the shifter?
Old 07-31-2014, 08:58 AM
djl's Avatar
djl
djl is offline
Received 2,031 Likes on 1,499 Posts
+1 on the compensator; very common problem and simple fix if caught before bad juju happens. '07 was the first year for the "new and improved" compensator that has now been upgraded twice and a special "kit" has been added to the parts list to address the "fretting" problem resulting from lack of lubrication. You need to pull the compensator and inspect and if "fretting" has occurred, replace it with the latest upgraded part and the kit or a better option may be to replace the compensator and install the Compensaver; an aftermarket cure.
http://www.compensaver.com/
If you do a Google search, you will see that there is a long history of compensator problems and failures that started with the new compensator in '07.
Old 08-05-2014, 11:51 AM
Jabrnet's Avatar
Jabrnet
Jabrnet is offline
Stage IV
So we found the issue this was rattling on the front drive gear.. It ate the belt but now the sound is gone... Question is, is this from my bike or from the road?
Attached Thumbnails Whine and Rattle from Trans on FLHRS-1407257443111.jpg   Whine and Rattle from Trans on FLHRS-1407257476603.jpg
Old 08-06-2014, 03:00 AM
131IRONMIKE's Avatar
131IRONMIKE
131IRONMIKE is offline
Looks like the tab from the rear ex.pipe bracket,JMO
Old 08-06-2014, 05:04 AM
Jabrnet's Avatar
Jabrnet
Jabrnet is offline
Stage IV
Looks like you are correct. Spoke with the local dealer and was told this was not the first time he's seen this happen and it could have been catastrophic should it have fallen half an inch to either side and landed on the bottom of the sprocket instead of the top. Seems like a poor design if these brackets are breaking off...Thanks for the input and help!
fwj
Milwaukee Eight (M8)
08-03-2021 04:18 PM
98FLHP
EVO
05-03-2017 06:37 PM
big- mike
02-21-2017 06:29 PM
JohnnyC
EVO
48
08-06-2014 09:22 PM
mtsumedi
09-26-2012 02:39 PM
Quick Reply: Whine and Rattle from Trans on FLHRS
