True Dual Heat Shield
I have the True Duals with Big Louie's on my 2009 FLHTCU, installed last summer. This has to be the best exhaust system out there, with the ceramic coating. Only issue I have is the front/lower shield clamps keep breaking, on the third one. Not sure if shield is warped. Tighten the middle clamp first, then lower and shield near head stands off the pipe, requires tension in order to place last clamp. Not sure if this is what's causing clamps to fail or not, I've tried marine clamps still no luck. Any ideas? Thanks.
Ryan
