Replacing a heat shield clamp
Old 08-11-2015, 01:42 PM
Donnybrook's Avatar
Donnybrook
Donnybrook is offline
Default Replacing a heat shield clamp
I stripped one of the heat shield clamps on my V&H Dresser Duals. Do I have to remove the heat shield to replace the clamp? Or can I just loosen the remaining clamps and install a new clamp?
Old 08-11-2015, 01:45 PM
Coastal CVO's Avatar
Coastal CVO
Coastal CVO is offline
It's basically a hose clamp, remove it and put a new one in it's place.
That is unless you have something else I am not aware of.
PS. if you loosen them all, you will have to re-align the entire shield and have the potential for rattles.
Old 08-11-2015, 05:42 PM
Donnybrook's Avatar
Donnybrook
Thanks Coastal. I think I'm going to run with the three that are remaining. If I have to remove the the heat shield, I might as well wait till I put it up for the winter.
Old 08-11-2015, 06:01 PM
mikeo33y's Avatar
mikeo33y
mikeo33y is offline
Ive stripped them out a few times. no. you dont have to remove heat shield but sometimes it makes it easier. not a big deal. plus. you can check the torque on your header bolts with the shield off
Old 08-11-2015, 06:55 PM
Vernal's Avatar
Vernal
Vernal is offline
Received 7,328 Likes on 1,912 Posts
Come on man it's just a hose clamp. Get a new clamp and fix it.
Speedspeed
11-30-2016 10:15 AM
Speedspeed
11-23-2016 01:38 PM
balloo
09-05-2014 08:23 PM
emanddd
Samson Exhaust
09-14-2011 07:13 PM
Griff012FLHX
09-04-2011 11:07 AM
Quick Reply: Replacing a heat shield clamp
