Engine upgrade
Old 04-15-2014, 03:30 PM
socko's Avatar
socko
socko is offline
3rd Gear
Default Engine upgrade
Hello everyone. I have a 2013 CVO Road King 110 ci and want to do the SE upgrade 27548-10A and Cam Bearing upgrade 24018-10. I will also be installing a Wimmer Super filter and want to add the SE Pro 58mm throttle body 27713-08 I spoke to Wimmer and Ryan told me no fitment problem since their bore in the bracket is 2.312 but my concern is will it mate well with engine upgrade. I would also like to install the SE Pro flow injector kit. My ride already has the SERT and V&H Power Duals with HI-output. I'm looking to stick with SE parts only for warranty issues and I'm not looking to enter any races just want to get the most performance out of this engine for daily runs and the occasional long road trips. I mostly ride solo daily and 2 up on long runs. Any and all suggestions and comments are greatly appreciated thanks
Old 04-16-2014, 11:30 AM
FXDFan's Avatar
FXDFan
FXDFan is offline
Don't see why it wouldn't work well. have roughly the same parts in mine, the 10.5, 259e, except I added the MVA ported heads as well. Next step for me is the 58tb and heavier injectors.
Old 04-16-2014, 02:46 PM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
09 YELLOWBIRD is offline
Thar set up may work out great for you.
However, I wouldn't trust the "warranty" part if you use Any of that SE parts.
Get it in writing from the dealership! Even a SEPRT voids your warranty!
YB
Old 04-16-2014, 03:23 PM
socko's Avatar
socko
socko is offline
3rd Gear
Thanks guys I'm gonna try and get this set up in a month
Old 04-16-2014, 09:32 PM
bigskyroadglide's Avatar
bigskyroadglide
bigskyroadglide is offline
if you are going to do upgrades to your 110, get the mva heads and change the lifters to s&s, I just had a lifter come apart in my 12 cvo 110, enough damage that i am now running a 120R. The lifter coming apart destroyed everything below the heads and throttle body
be aware....
Old 04-17-2014, 04:39 PM
socko's Avatar
socko
socko is offline
3rd Gear
Thanks bigsky. How is the 120R for day to day
speakerfritz
07-19-2011 09:54 PM
Rebel78
Exhaust System Topics
06-22-2008 02:58 AM
Lord Albany
05-09-2008 02:02 PM
Lord Albany
04-24-2008 09:45 PM
ducedan
11-30-2005 04:49 PM
Quick Reply: Engine upgrade
