5 speed clutch adjustment
just finished cleaning up some minor wiring issues with the turn signals (and added a Badlands module). I can't get the clutch to stay adjusted. Sitting cold, adjust the pushrod per the book, and all is good. Plenty of pull on the handle. I go ride it and I lose handle resistance within a couple of blocks. I head back home and repeat the rod adjustment. regained the handle and all seems good again. I go for another ride and same issue; lose the handle resistance within less than a mile. Bike is an 80 FLT factory 5 speed. New cable, clutch discs look in great shape. What am I missing in my adjustments?
I have always tried to get the clutch actuator "fingers" at the best angle. then Adjust the cable to that clutch arm position.
The actuator is just like the 4-speed, Inside.
The trick is to have the angle just right, so the throw is optimum.
Also...Be careful that the actuator Fingers [against the throw-out bearing] are Not Contacting the Mainshaft....you can break the fingers...
If ya need to...Open the right side up and look at it....All will be revealed.
Edit; I just got to thinking about it...and I think that if you remove the adjusting screw from the Pressure plate [clutch side of course] you can push the pushrod in with yer finger against the throw-out bearing and arm ...this will give you a feel for where the arm needs to be at the begining of the "stroke". Adjust the screw for this arm position to start...
Damn...I ain't no good at explanations am I!!!!
Your throwout bearing may be the problem. If it is failing, you don't want that metal in your transmission oil.
I agree with the first reply, pull the right side cover and look for the problem there.
Of course, the clutch cable could be failing. Check for broken strands at the hand lever and inside the right side cover while you are in there.
Well, took off the side cover and my throw out bearing is totally trashed.
Now to see tomorrow if my indy has anything at his shop; if not, then off to eBay I suppose. Gotta do a good flush job, too...there's alot of filings inside the side cover, so the rest of the case is likely full of the same trash.
What's the "big umbrella looking" part used for in this eBay kit...say's it's supposed to fit my bike, but my book only shows a roller bearing between 2 thrust washers.
Attachment 419590
Attachment 419590
