1986 fourspeed
1986 fourspeed
I have a question from my85-86.service manual. Tranny section the tolerance for the bushing to main shaft says(loose) . Does that mean that's where it should be BEFORE I press it into the main drive gear? Assuming it may change after I press it in...
I may be digging in there soon and want to make sure I can do this.
Bushings are usually tight after being pressed in and have to be either honed or reamed to size. Some aftermarket bushings are a bit oversized and once pressed are very close to right you just have to check. Look for wear on the mainshaft also if it's grooved any it's replacement time or the new bush won't last.
harley has used that term loosely - its a machinist term meaning sized to the correct and fit up lose to the touch, with no binding at all any place in the circle as you turn it
we hone to fit them and you can easy do to much if not careful
its loose not movement in the two pieces
Just thinking if I want to tackle the job myself or take you up on your previous offer. The spacer with o- ring was a good mod but obviously the bushing is worn because it's leaking pretty bad, an some movement in the pulley, not a lot but some. Bearing may be replaced also.
4 bearings are in that trans = the main ball right side - hi gear / 4th gear left side same one in the case timkin type - and the 2 inside of the counter shaft - should be on the list as they were last replaced together - as twist said the area covered by the bushing is suspect for wear, as the bushing material is tougher then the steel on the mainshaft, and once is bites in as the bushing wears it wears a ditch in the main shaft - it ends up the area on the shaft that the bushing rides, becomes smaller then the area the primary bearing rides, so you cant get it on its location in spec it will always be loose the kind that leaks oil by loose
Just looking to do what should be done to it.PM me if interested and we'll talk...
Thanks
