Is it safe to drill and tap a lower tree?
Before you waste your time, check the width of your nacelle to the trees. I believe FLH trees are a different width then the wide glide. They made a kit for mounting a nacelle. It consisted of several brackets that attached to give you anchor points for the nacelle and the cow bells (chrome fork covers)
Bill wallace (12-03-2016)
you could probably make the top tree work...couple of bottom trees on ebay right now for $40
http://www.ebay.com/itm/Harley-Lower...JX4vAH&vxp=mtr
http://www.ebay.com/itm/Harley-Lower...VX4vLR&vxp=mtr
41mm is 41mm...the trees you have, if Real FXWG trees have more worth than typical FLH trees...
For the old cast Elephant head nachelle, About any old [pre-85] FLH trees will work. If I was going to go with Tin [panhead/softail style] I would go ahead and use Softail trees, as the Width is enough different to present problems with mounting tin.
joetom08
05-02-2013 09:48 PM
FlatIron
07-16-2012 07:26 AM
JohnnyBravo
01-27-2010 11:38 AM
