Fork Stem
Old Feb 17, 2017 | 04:49 PM
jqb12's Avatar
jqb12
Default Fork Stem
For you guys that have done the mid-Glide to Wide Glide conversion, how difficult will it be to remove the stem from the lower tree and then install to the new lower tree? I've got the rest figured out with your guys help. Or, should I just try and find the entire triple tree?
thanks
Old Feb 17, 2017 | 06:17 PM
multihdrdr's Avatar
multihdrdr
Where/how would you be getting just a lower tree without the stem?
Are you still looking for Wide Glide Trees?
Old Feb 17, 2017 | 07:36 PM
jqb12's Avatar
jqb12
Well, my plan was to buy the top and bottom separately from V-Twin and go from there, but........I'm thinking that may not be the best idea, so yes I'm looking for wide Glide trees.
Old Feb 17, 2017 | 07:48 PM
Ghost_13's Avatar
Ghost_13
Once it disassembled - remove the snap ring - press out the stem
Then press the stem into the new lower / install snap ring
Need a 20 ton press..., or bigger - its in there tight as hell - and makes a bang when it finally lets loose
Haven't done this particular swap on a harley - did on two dirt bikes I raced
Same process
Ghost
Old Feb 17, 2017 | 07:53 PM
multihdrdr's Avatar
multihdrdr
Don't they come with a stem (I think it would be odd without). The V-twin pics I see, show a stem.
Also you didn't respond to your WTB thread ... I may have set
Old Feb 17, 2017 | 07:59 PM
multihdrdr's Avatar
multihdrdr
Same process
Ghost
That's what gets people into trouble. They come out counter-intuitively.
You press from the the threaded end (top) out the bottom. Install by pressing into the bottom from snap ring side.
In fact you could leave the snap ring installed the whole time
Old Feb 17, 2017 | 08:15 PM
jqb12's Avatar
jqb12
let me know what you have
Old Feb 17, 2017 | 08:26 PM
Ghost_13's Avatar
Ghost_13
You could - but you also stand a good chance of breaking the snap ring when it lets loose
Learning from another's experience..., is by far better than from one's own **** ups
Ghost
Old Feb 17, 2017 | 08:48 PM
jqb12's Avatar
jqb12
Ghost
thanks for the help
Old Feb 18, 2017 | 06:03 AM
multihdrdr's Avatar
multihdrdr
Ghost
Huh...breaking the snap ring???
My point is that people try to press out the stem the WRONG way. Because they think you have to remove the snap to get it out.
With the snap ring on when installing, it can act as your stop
