72 FX Engine swap possibilities???
Old 12-26-2016, 07:02 PM
DJ72FX's Avatar
DJ72FX
DJ72FX is offline
3rd Gear
Default 72 FX Engine swap possibilities???
Hey everyone I am new to this forum. I have a 72 Harley FX Superglide that I am building from boxes of parts and I need some input on my engine options. My situation is that I have the shovelhead motor for the bike along with the kick start 4 speed trans. I am tearing down the motor to the short block for a full rebuild, but it seems like the motor is going to need just about everything ($$$$$). So with my hotrod mentality I am wondering if there is any later model engines I can swap into my bike and bolt up to the 4 speed trans without extreme modifications. Please bear with me if this is a stupid question; I am still fairly new to Harleys.
Old 12-27-2016, 12:28 AM
FilthyLucre's Avatar
FilthyLucre
FilthyLucre is offline
In a Harley 4 speed frame you can fit a Knuckle 1936 to 1947, a pan 1948 to 1965 or a shovel 1966 to 1984. The frame does not have enough clearance to use a later model motor without major modification.
Old 12-27-2016, 06:59 AM
Carlos Frijoles's Avatar
Carlos Frijoles
Carlos Frijoles is offline
Thanks for asking the question - I had wondered the same thing. You can also look in to buying a "crate motor" that is completely rebuild (S&S sells them, for example) but unless the shovel you have is completely trashed, you can do most of the labor for less. I am going through this process on a '79.
FilthyLucre - great reply! I need to save this in my notes somewhere... the "mental notebook" I use it not so reliable these days!
Old 12-27-2016, 08:29 AM
V_twins's Avatar
V_twins
V_twins is offline
mmm... wouldn't an EVO fit? Weren't there early EVOs with 4 speed trannies on shovel frames?
Old 12-27-2016, 09:01 AM
Joe12RK's Avatar
Joe12RK
Joe12RK is online now
Received 1,412 Likes on 881 Posts
DJ - you have one of the earliest years FX - you should seriously consider keeping the motor stock looking, at least. If if needs as much as you say, go for more displacement while you rebuild it.
V-T they modified the frame to fit the taller EVO motor.
Old 12-27-2016, 12:39 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,247 Likes on 5,408 Posts
EVO FXWG's were 4 speed frames that were modified... while they were making them...to fit the EVO enigine.
An EVO will not fit in a regular 4 speed frame...Google "EVO in a shovelhead frame" and you will see pages of people who have done this. Quite a bit of work to ruin a perfectly good frame.
TwiZted Biker (01-01-2017)
Old 12-27-2016, 10:48 PM
Hey Man's Avatar
Hey Man
Hey Man is offline
Received 7,004 Likes on 2,817 Posts
The motor is too tall.
Old 12-27-2016, 10:50 PM
Hey Man's Avatar
Hey Man
Hey Man is offline
The motor mount pattern is the same but the motor itself is too tall.
Old 12-28-2016, 10:34 AM
V_twins's Avatar
V_twins
V_twins is offline
Oh thanks... I didn't know they modified the frames to fit the EVO
Joe Pritts
05-12-2016 10:31 AM
gnafin
EVO
08-16-2013 09:54 PM
4stroke
Shovelhead
04-07-2013 01:42 AM
ink n bones
Custom Models
08-30-2008 05:00 PM
ty27
Panhead
04-11-2008 02:56 AM
Quick Reply: 72 FX Engine swap possibilities???
