Bigger Rear Tire '80 FLT
I have an '80 FLT that needs new tires. A friend of mine gave me an almost new set off of a newer bike. The front is the right size, MT90B16. The rear is a MU85B16. Question is, can I use the bigger 140mm tire on the rear? I know the MT is 130mm so the MU will be 10mm wider. Will I have clearance issues with the enclosed chain, fender etc? As you may know, it's way too much work to pull the rear tire on & off to guess and check!
KnarleyHarley
03-02-2017 01:52 PM
