leaking push rod tube
I have been battling this for awhile,its the front exhaust tube I will get it fixed and it will hold for a while and then start to leak .I have went to a smaller push rod because of the rub and i have shimed under the tube spring to tighten it up with no luck.I noticed today that the end where the push tube meets the rocker box the tube isnt sitting flatand thats where my leak is coming from ,the tube end looks good and the recess in the rocker box is clean but when I extend the tube from the block to rocker box there is a 3/16 gap from one side to the other in the rocker box?!?! has anyone had this problem?
