Strange Rocker Box Question
Old Apr 5, 2011 | 08:51 AM
2006FLST's Avatar
2006FLST
Default Strange Rocker Box Question
Okay this beats all I have seen. Just noticed this last night on the rear rocker box of the bike I just picked up. The middle rocker box on the rear is off center. It is actually sitting off set to one side. I can’t remember which side but I have never seen that. No leaks at all. Motor is stock. Previous owner had it 7 years and only changed the basic fluids per the shop manual. What do you guys think? I have never pulled rocker boxes.
Old Apr 5, 2011 | 09:11 AM
Havoc88's Avatar
Havoc88
I've had this one before, more than likely the box gaskets were replaced do to seepage or a leak and when reinstalled they were not alligned correctly, I would try loosening the bolts, reallign the spacer, and retorque and see if it leaks. but if you want to replace just the box gaskets then go for it?
Old Apr 5, 2011 | 09:15 AM
2006FLST's Avatar
2006FLST
I just can't beleive it has been like that for so long with no problems. I may pull the top end in about a year. Is it something I should try to address right away or could I hold off. I just want to make sure the top end is getting oil.
Old Apr 5, 2011 | 09:17 AM
Mike T's Avatar
Mike T
IMO if it's not leaking, leave well enough alone. Goes back to the old saying "If it ain't broke, don't fix it".
Old Apr 5, 2011 | 09:19 AM
2006FLST's Avatar
2006FLST
It is clean as can be and does not bother me. I just want to be sure I am not looking at some disaster. I guess a drunk blind man put this one on (no offense to drunks or blind people)
Havoc88's Avatar
Havoc88
I would think its fine, more appearance than anything, as for oil you would know by the knocking if you weren't getting oil I think. But hey James Gaskets are made in the USA, I love there box gaskets and its a great chance to crack the boxes for a looky?
Old Apr 5, 2011 | 09:25 AM
2006FLST's Avatar
2006FLST
Well I am popping an EV27 in there very soon with the help of a very good wrench. So maybe I will pop the tanks and give her a look. It does have a tick (nothing major) but I figured new lifters/pushrods might cure that with the cam. When I get her running again I will get close to hear where it is coming from.
Old Apr 5, 2011 | 10:05 AM
#1rocketman's Avatar
#1rocketman
I gotta agree with Mike.....if it weren't sealed up,it sure as hell would be seaping some oil and you'd see it.If you're planning on doing a cam change and probably lifters and pushrods in the near future,then do the rocker box gaskets then. If you try loosening the boxes up and realigning them,make sure the rubber gaskets don't move out of their groove or you will have some leakage.It's not hard to remove the boxes,you won't even have to remove your gas tank,Just loosen the tank raise it up,wedge something under it to hold it up and go about your business on the boxes.
As for gaskets,you'll find brands are about like the oil discussions on which is better.James are good,I used Cometic on my ole 92 and again on my 98 with no problems. Good luck and let us know what you do.
Old Apr 5, 2011 | 10:08 AM
2006FLST's Avatar
2006FLST
Thanks guys. I love the answers I get in the evo section. So to sum it up it sounds like I really don't have much of a concern. But since I will be tearing into the motor a little it might be a good idea to line it up.
Old Apr 5, 2011 | 10:23 AM
#1rocketman
There ya go!
