dual plug coils ??
dual plug coils ??
I have a 66 shovel engine with dual plug heads.. i also have a mallory electronic "distributor" and a set of dyna 3-ohm green coils.Mallory suggests using 2-4 ohm coils...no more than 5 ohm total..so if i tie the 2 coils together do i get 6-ohms of resistance ??? the coils came off of a dual-plug shovel so would anyone know if i could safely use them or do i need to buy a new set ??? I also have the original "circuit breaker" distributor...would these coils work with that ??? if not than exactly what are these coils for ??? Thanks..
No doesn't work like that,,,A 3 ohm coil is used for a fully electronic ignition,(dyna 2000,,twin tech,,compu fire) A ignition similar to a dyna S or vulcan still has an advance weight system,,they want 5 ohms same as points..You can run 5 ohm with that timer for street use,,,3 ohm for race...The 3 ohm coils will heat up when running for a long distance ...When wiring coils for single fire dual plug,,you have to consider wiring in parallel or series,,,I'm not sure if that timer can do single fire,,,The Vulcan unit can fire single or dual,,3 or 5 ohm..
Dave
Dave
Hi TwiZted Biker,
I am hoping you can share some of your expertise please.
I have a Shovelhead dual plug dual coil dual fire. I am looking for a simple wiring diagram.
It is a custom chopper that only has headlight, tail light, brake light, ignition.
I have headlight, tail light, brake light working, power to the coil just not sure the wiring of the coils. Not where wire from the points connects, but have power to the points. Maybe that isn't very clear, but I am stuck and would appreciate any advice.
Thank you!!!!
TooBlue
Thank you!!!!
TooBlue
Looking for Help
Thank you!!!!
TooBlue
Hi TwiZted Biker,
Thank you!!!!
TooBlue
Thank you!!!!
TooBlue
Two 3 ohm coils wired in Parallel will give something less than 3 ohms total... while 2, ea. 3ohm coils wired in series will result in 6 ohms... just right for the typical Dyna-S type ignition... so... wire two of the dual tower 3 ohm coils in series..
that is 12v on one coil and triggers to the other one... coils tied together in to out...
Stiggy (05-17-2020)
I know you did not ask me but... easy ****...
Thank you! Everything was running perfectly before I took it apart for this rebuild. I have points. The two coils are wired in series. I have 12V at the points but no spark at the points. It could be a condenser problem was another thought...
Racepres (05-18-2020)
