Filter wrench for a WIX 57148 filter?
Old 09-26-2016, 04:27 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
Default Filter wrench for a WIX 57148 filter?
Anyone using this filter on their Twin Cam that can tell me which size filter wrench it takes?
https://www.amazon.com/dp/B004AHFXCE...I3EHKOAHMKPUZC
Old 09-26-2016, 05:00 PM
JohnMn's Avatar
JohnMn
JohnMn is offline
Same size as stock,, the one down your linked page that say's it's for Harley will work.
Old 09-26-2016, 05:05 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
Your saying the 76mm 14 flutes will work for the WIX then?
Old 09-26-2016, 05:57 PM
Ghost_13's Avatar
Ghost_13
Ghost_13 is offline
Received 7,034 Likes on 2,936 Posts
A stock filter wrench..., and when I say stock - I'm referring to harley stock - is too small
The right size wrench will also fit automotive WIX and AC delco filters
If you need me to measure it - it'll take a day or two
Ghost
Old 09-26-2016, 06:08 PM
JohnMn's Avatar
JohnMn
JohnMn is offline
Ghost 13 could be right.
I just use a common automobile small filter strap wrench, hasn't failed me yet.
Old 09-26-2016, 07:56 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
For anyone referencing this thread in the future, it looks like the 74/76mm 15 flute filter wrench is the right one. I won't be able to confirm it until I buy one and that won't be for awhile since I've got 1k miles to put on the bike before my next oil change.
Old 09-26-2016, 08:34 PM
robertomendo's Avatar
robertomendo
robertomendo is offline
I bought the Harley filter wrench for my Switchback and it only works to remove the filter not to tighten one when changing filters. I bought a strap wrench that works fine with any filter.
Before you all remind me that you only tighten hand tight I will say that there is no room on a Switchback to even get a couple of fingers in there.
Old 09-26-2016, 08:45 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
Same thing with my Dyna, there's no room to put a strap wrench between the down tubes on the frame. If I'm going to remove or install a filter, it needs to be done straight out from the filter not from the front between the frame tubes. Now, the WIX filter appears shorter than the oem filter. The filter wrench does not bind on the CPS (crank position sensor) so that problem is solved.
Old 09-26-2016, 09:24 PM
robertomendo
The strap on my strap wrench is attached to a socket that takes any 3/8ths extension from the front of the filter. Works perfect on a dyna. I got it at Amaze On. Is is called a motion pro oil filter strap wrench 08-0069 and cost $11.73. Expensive yes but it was the perfect solution to tightening the filter just right.
Old 09-26-2016, 10:29 PM
JohnMn's Avatar
JohnMn
JohnMn is offline
google this;
swivel head oil filter strap wrench.
I got the good one, it cost $7
Quick Reply: Filter wrench for a WIX 57148 filter?
