Low Rider S license plate relocate and t bars
just flipped my street Glide in for LRS. First off, I hate the license bracket location and want to move it. Second off, I want to put a set of club style t bars on, but not sure what size and what cables, wires and extensions need to be made. The dealer is quoting me $800 for an install, but it seems straightforward enough to do unlike mini apes on a bagger. Anyone want to give their input on these issues?
If you don't want to do the long fender conversion, Id go with a lay down plate and Alloy Art strut mounted LEDs. They're super bright and easy to install. For the bars, you won't be needing wire extensions. There is PLENTY of wiring in the frame of the bike. I went with lines from Magnum Shielding and Lucky Daves 14" bars.
You can see the wiring here:
http://https://www.hdforums.com/foru...-thread-7.html
I went with the great bike gear kit too , modified it a bit, so I could tuck an led tail light up under the fender. I cut the tab off for the plate illumination lamp , which is an optional / add on part from Great bike gear. Our plates are huge , there was no room for the plate illumination lamp , the l.e.d. strip more than lights up the plate , it's a brake light too. Those are available from Drag specialties or J.P. cycle.
