Harley Davidson 883 Iron
Old 02-20-2017, 03:05 AM
devoniron's Avatar
devoniron
devoniron is offline
Stage IV
Default Harley Davidson 883 Iron
Hi folks,
I have recently had the pleasure of owning a 66 reg 2017 model 883 iron, i have done only a hundred or so miles but already seems to be a very hard ride on the rear springs. I have adjusted for rider weight and tried a few marks each way but still seems hard in the old spinal area, I think this newer model has the cartridge preload shocks fitted as standard as part of the 2015 upgrade/makeover. Has anyone decided to swap out these stock shocks for a pair of progressive 412 maybe ? Some forums say the 412 are no better.
Any advice welcome
Chester
Old 02-20-2017, 04:36 AM
LoneWoolf's Avatar
LoneWoolf
LoneWoolf is offline
Consider this for your tender fanny. https://airhawk.net
Old 02-20-2017, 07:26 AM
devoniron's Avatar
devoniron
Stage IV
Thanks LoneWoolf..
Old 02-20-2017, 07:52 AM
LoneWoolf's Avatar
LoneWoolf
Chester, the Airhawk has been in use by many riders for over 40 yrs. Many of my former BMW associates spoke very highly of them, and of course, they can be used on any bike you might ever own. Good luck.
Old 02-20-2017, 08:57 AM
devoniron's Avatar
devoniron
Stage IV
No worries buddy...worth a go I guess
Old 02-20-2017, 09:17 AM
baka1969's Avatar
baka1969
baka1969 is offline
The progressive shocks are a decent upgrade. I would also suggest getting at least 1" longer shocks that will make a significant difference.
I also have the HD Zeppelin Air Pad which is a HD badged Airhawk. I use it for traveling and does an excellent job.
devoniron (02-21-2017)
Old 02-20-2017, 12:33 PM
drinktothat421's Avatar
drinktothat421
drinktothat421 is offline
12.5 or 13 inch shocks is my option get that sportster "long travel" 3"
Old 02-20-2017, 01:55 PM
Guzzi's Avatar
Guzzi
Guzzi is offline
Used air shocks from a street glide or similar model sell here and on Craigslist in the $50-$100 range. They have a good reputation here on the sporty forum for improving the ride. for You may need a 1" lowering kit to get correct ride height.
Old 02-21-2017, 09:36 AM
Almond farmer's Avatar
Almond farmer
Almond farmer is offline
Four factors that increase spline & riding comfort level.
1. Riding position, leaning forward cafe racer style with rear controls, straight up with mid
controls, lean back with back rest with forward controls
2. Softer shocks, the longer the spring with fixed wire diameter and coil diameter
the softer the ride to reduce impact shock.
Replaced my 883C shocks with longer roadsters shocks.
The 09 883/1200C shocks were softer than the 08.
3. Thicker cushion with lower foam density seat reduces vibration forces.
The reason the Mustang Vintage and Mustang Wide Touring seat
with 3" thick, 2-3 #/CF density foam are so popular.
The mass produced ,one seat fits all, approach.
4. Seat contour to reduce pressure areas on the buttok
Corbin Saddle will custom contour a high density , 7#/CF, closed cell foam seat to fit the
rider. This approach reduces pressure points but does not isolate vibration forces as
much as a thick low density foam seat. Silicone gel isolates vibration forces either
inserted into a foam seat or as a separate comfort pad.
Prefer the comfort pad for long trips.
There are probably other factors that affect spline and butt comfort.
Old 02-21-2017, 09:49 AM
devoniron's Avatar
devoniron
Stage IV
Thanks to everyone for the advice..
Chester
Quick Reply: Harley Davidson 883 Iron
