Returning Member needs Ideas
I wanted to start getting into doing things on my bike my self. Never worked on a bike before. I figured I could start with small things:
- Removing the seat to check the battery
- Remove bags and put back on
- Checking the fluids
- Changing the oil
Received 14,347 Likes
Removing seat, bags and checking fluids are very simple things that even those who do not work on their bike should be able to accomplish and do as part of normal routine maintenance and cleaning. As others have said get a service manual it will help with those, its likely that even your owners manual will show you how to do those routine things.
Service manual is essential. Make sure you have all the proper tools for the jobs you will do. Get the best quality tools you can afford. YouTube is a big help to visualize the job. Be patient. Never force an issue. That is how you break something. If you get frustrated, just set the tool down for a few moments and calm down. Reassess and try again. Profanity is allowed and encouraged.
Good luck
Good luck
Received 4,368 Likes
