help on internal front brake line.
I would like to swap to internal throttle and front brake line on my apes. Thought about swapping to Gangsters but will save my money and stick with my current 16"s.
I noticed 2 members drilled a hole in their bars and ran the front brake line through the bars. I'm trying to figure out what size line and what fitting they used on the master side. It looks like it comes straight out of the master as opposed to the banjo I have now.
I'm going to run exile cycles throttle. Hoping it's a straight forward install.
Here are the part numbers I used for my internal line. Ordered them from JP Cycles. I found it was best to lightly heat the line at the bends to get a tighter radius, careful not to crimp it though. The fittings are very straight forward compression ring type. I ordered the extra olives and banjo washers just in case I buggered one up, but didn't need them.
241-669 Brake Line
240-0172 Straight fitting (black chrome)
240-0177 35* Banjo Fitting (black chrome)
972-649 Extra banjo washers
240-687 Extra olives (comp rings)
Good luck on the project, you'll love the exile throttle, high quality piece. Keep us posted on the progress!
241-669 Brake Line
Thans brother! Is welding on the exile necessary?
I'm also wanting to swap to hydraulic clutch ran internally. I see one that uses the stock cover and changes the ramp. Then another that replaces the cover with a big push rod. Any one better then the other? One is about 175 and the other is 250 or so.
IMO, the throttle should be welded in, but it does come with set screws if you would rather not go through the hassle. I chose to weld it, heard from a few people who had some issues with the stability from the set screw setup.
I don't know anything about the hydro clutch conversions, but it sounds like you got that sorted already.
As for the brake line, not sure how you'd transition back to a stainless braided line. There are other systems out there besides the Russell one that I used, but can't recall the manufacturers. Maybe just black out the sled, makes finding parts so much easier! Lol
