Locktite on exhaust nuts?
Old 08-05-2015, 03:24 PM
Jersey Drew's Avatar
Jersey Drew
Jersey Drew is offline
Default Locktite on exhaust nuts?
Had the front cyl exhaust come loose today after about 2k miles. I torqued to spec of 120 in/lbs (10 ft/lbs). Should I have put locktite on those studs?
Old 08-05-2015, 04:07 PM
jm35ny's Avatar
jm35ny
jm35ny is offline
I would never locktite exhaust studs, just neversieze them. Retighten them and ride
Old 08-05-2015, 04:08 PM
rocknrick's Avatar
rocknrick
rocknrick is offline
In a word - no. My manual actually says torque to 60-80 in/lbs.
Old 08-05-2015, 04:16 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
Anti seize! Torque to spec. Check every oil change.
Old 08-05-2015, 04:20 PM
Jersey Drew
mine says 100-120 in/lbs
didn't make it to the next oil change.
Old 08-05-2015, 04:52 PM
FXSTI 88's Avatar
FXSTI 88
FXSTI 88 is offline
Stage II
Have never used loctite on the exhaust nuts. Just tighten them firmly and they will stay in place.
Old 08-05-2015, 09:29 PM
ADRENALINE RUSH's Avatar
ADRENALINE RUSH
ADRENALINE RUSH is offline
Anti-Seize and torqued by a properly working torque wrench. they can go out of calibration.
my fleet mechanic has his snap on guy check his snap on torque wrenches for calibration every 3-4 months. it had to be sent out for recalibration once or twice in the past few years. I've never had mine professionally checked, but then again i have 4 different sizes and they have never been left under load (always spun down as low as it goes after use so theres no tension on the spring, otherwise the spring will be stressed and your values will change), they also don't get too much use, are kept in the case, and have never been dropped. if yours have been subject to any of the those mentioned things its probably out of calibration.
heres an intersting video about calibrating a torque wrenches yourself using a calibration testing tool and adjusting the torque wrench. its pretty interesting info from 1:50- 2:30, at 3:25 you can see his is 10 lb off! some more interesting info at 6:25-6:50. i stopped watching there, but it seems like a pretty cool video. theres other complete do it your self videos with out using a calibration tool, but i dont think i would fully trust those methods.
Old 08-06-2015, 12:08 AM
Next In Line's Avatar
Next In Line
Next In Line is offline
If they come loose again, use a lock washer.
Old 08-06-2015, 01:12 AM
Lostrider's Avatar
Lostrider
Lostrider is offline
Unfortunately vibration will loosen anything up. But loc-tite on exhaust bolts is always a no-no. Anti-seize is your friend.
Old 08-06-2015, 04:33 PM
Strahley's Avatar
Strahley
Strahley is offline
I use anti-size and lock washers, and check them every other week or so (mine are very easy to get to so it only takes about a minute to check them all). Never had one come off, and it's rare for one to even come even just slightly loose (I give credit to the lock washers for that)
I would highly advise against using loctite on them
Quick Reply: Locktite on exhaust nuts?
