Hydraulic tensioner wear check
Old 12-13-2015, 12:02 PM
gtmalone's Avatar
gtmalone
gtmalone is offline
Default Hydraulic tensioner wear check
55K since the upgrade - '07-up version.
Checked the hyd tensioners for wear - maybe 1/64". The pic makes it look like more. I'll worry about it after another 100K.
Mobil 1 change every 5K.
Old 12-13-2015, 12:22 PM
bad tappets's Avatar
bad tappets
bad tappets is offline
Glad you posted that info, I have been curious as to how the hydro tensioners are holding up.
Did you check the inner as well? Do you have morse or roller chain on the inner?
Old 12-14-2015, 09:47 AM
gtmalone's Avatar
gtmalone
gtmalone is offline
It's the HD '07-up version. Roller chains, complete replacement of all cam parts and oil pump.
You may have to pull the cam plate to see the secondary tensioner. Might be able to use a dental mirror to see it.
Old 12-14-2015, 06:38 PM
spydyr's Avatar
spydyr
spydyr is offline
I did a cam job on my '09 Fatboy with 100K on her. I bought replacement tensioners thinking they'd probably need replacing, but they were barely worn at all. Since I got them anyway, I went ahead and replaced them, but just food for thought.... hydraulics last a loooooonnnng time.
Old 12-14-2015, 07:10 PM
splattttttt's Avatar
splattttttt
splattttttt is offline
Thanks for postin this Malone. Never hurts to see how others fair.
Old 12-14-2015, 08:10 PM
bad tappets
gtmalone, spydyr;
Thanks for the replies, good to hear the hydros are holding up well.
EarlB
Engine Mechanical Topics
08-07-2018 09:19 AM
Gliden
02-23-2017 05:21 PM
Angle or Demon
Exhaust System Topics
09-25-2013 08:49 PM
dmathieu
03-10-2012 06:02 PM
71chev
02-13-2011 07:36 AM
Quick Reply: Hydraulic tensioner wear check
