03 Fatboy carb issues
Old 01-20-2016, 02:25 PM
tl1023's Avatar
tl1023
tl1023 is offline
Stage II
Default 03 Fatboy carb issues
Didn't ride much last year and couldn't get bike to run. Purchased the CV Performance carb kit and installed with no issues. Motor cranked right up but after warm up, began to run rich and mixture adjustment had no effect. Installed smaller pilot jet, new float needle valve, and adjusted float level to HD specs. Problem continued. Installed even smaller pilot jets from CV and, while problem is better, still runs too rich with mixture screw turned in completely. I have Rinehart exhaust and Screaming Eagle intake. Right now, I have 185 main and 42 pilot jets but problem has been similar with several variations of jets. Ideas?
Old 01-20-2016, 02:31 PM
DK Custom Products's Avatar
DK Custom Products
DK Custom Products is offline
Sponsor
My first thought is to check your enrichener and be certain it's closing all the way; sounds like it's stuck open.
Edited to add: Welcome to HDForums!
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
Old 01-20-2016, 08:51 PM
tl1023's Avatar
tl1023
tl1023 is offline
Stage II
Thanks. Enricher appears to be working perfectly.
Old 01-21-2016, 08:08 AM
hdbob2006's Avatar
hdbob2006
hdbob2006 is offline
Then check your float adjustment. Hope you have instructions to set the float height as it is critical.
Old 01-21-2016, 08:17 AM
H-D Nomad's Avatar
H-D Nomad
H-D Nomad is offline
I would check the float. The plunger that seals off the fuel flow when the float bowl is full could be worn or dirty and not sealing properly thus letting through to much fuel. I would check this before trying to adjust the float height. It's very easy and cheap to change. If this is sealing perfectly then check and adjust the float level, assaid before its critical to be set correct. Hope this helps you out.
Old 01-28-2016, 11:10 PM
ffatboy03's Avatar
ffatboy03
ffatboy03 is offline
Put a Mikuni carb on it.
Old 01-29-2016, 01:23 AM
LA_Dog's Avatar
LA_Dog
LA_Dog is offline
Welcome! Float level more than likely - And yeh get a Mikuni
The1stman
Carburetor Related
15
04-10-2015 08:08 PM
skinman13
06-30-2014 02:43 PM
GimmeAHammer
05-19-2014 04:46 PM
rwbbts
Exhaust System Topics
07-23-2010 02:01 PM
slammed05fatty
07-20-2010 01:14 PM
Quick Reply: 03 Fatboy carb issues
