Wiring to Install tag Lights on '16 BO
Old 03-25-2016, 11:57 AM
doo925's Avatar
doo925
doo925 is offline
Default Wiring to Install tag Lights on '16 BO
Hey guys, I'm installing a side mounted aftermarket license plate bracket on my '16 Breakout. This means I need to install tag lights (which I've ordered from Custom Dynamics). Does anyone have advice on how to get the tag lights wired up correctly? I've contacted Custom Dynamics on this subject and they said to run the black wire from the tag light to ground on the bike and the white wire on the tag light into the blue wire on the bike which should be the running light wire. Anyone know where to find the blue wire and suggestions on a ground point ? Pix would be a great help.
Old 03-25-2016, 10:01 PM
stal94gt's Avatar
stal94gt
stal94gt is offline
The blue constant power wire can be found under the seat. On the same wire harness you will see a solid black wire which is ground. Additionally the frame is grounded but sometimes the ground signal is weak threw the swing arm
This is a picture of a run/brake/turn module but it shows what the wire harness looks like
Old 03-26-2016, 10:23 AM
doo925's Avatar
doo925
doo925 is offline
Awesome, this helps a lot. Thanks for the pix !!
mstrobes
2014-2023 Touring Models
06-27-2015 09:44 PM
WARG
10-18-2010 09:22 PM
jarhead45
07-02-2009 12:24 AM
magmini
06-29-2009 04:36 PM
jmsoftail94
04-24-2008 06:36 PM
Quick Reply: Wiring to Install tag Lights on '16 BO
