2007 so frail deluxe backfiring on acceleration
Old 07-10-2016, 08:10 PM
felipeanthonyroman@hotmail.com's Avatar
felipeanthonyroman@hotmail.com is offline
Stage III
Default 2007 softail deluxe backfiring on acceleration
Hello,
My bike was sitting for a year. It was fine when I stored it.
I replaced the battery and started her back up but I noticed she would backfire out the exhaust when I pull the accelerator. I drained and replaced the fuel but it is still backfiring. I tried riding it up the street but it won't accelerate without losing power when it backfires.
Last edited by felipeanthonyroman@hotmail.com; 07-10-2016 at 08:11 PM. Reason: Spelling errors
Old 07-10-2016, 08:31 PM
checkers's Avatar
checkers
checkers is offline
Originally Posted by felipeanthonyroman@hotmail.com
Hello,
Treat fuel tank with 4 oz of Startron fuel additive and run the engine. Recheck your battery cables and make sure they are installed correct, allconnections that are hooked to your battery are installed and tight. Also search the forum with regard to fuel line inside tank issues. I assume you are fuel injected
Old 07-10-2016, 09:57 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
Sounds as though it's developed an intake leak somehow. Your bike is 10 years old, seals start to deteriorate after a few years. Start the bike and then spray a little WD-40 around the intake manifold. If the bike bogs down, there you go.
Old 07-10-2016, 10:29 PM
Stage III
What do you mean by bogs down?
Old 07-10-2016, 10:53 PM
baloot-boy's Avatar
baloot-boy
baloot-boy is offline
He means you should hear a change in idle like its struggling.
Old 07-10-2016, 11:46 PM
Next In Line's Avatar
Next In Line
Next In Line is offline
Sounds like the fuel regulator is not good if it loses power under acceleration.
Do a fuel pressure test and make sure it is a constant 58 to 62 psi no matter what the throttle position is at.
Old 07-12-2016, 02:23 AM
Stage III
Turns out I over torqued one of the spark plugs. It was damaged by the cylinder head. I re gapped both plugs and replaced the ignition wires. She's running great!
deluxegal
01-10-2018 08:33 AM
scooby636
08-29-2013 04:28 PM
Dergs713
EVO
07-30-2012 11:53 AM
blacksportster05
02-13-2011 06:34 PM
Tommo
12-02-2007 04:48 PM
Quick Reply: 2007 so frail deluxe backfiring on acceleration
