Missing Oil
Missing Oil
I picked this bike from my dad. 2003 FXST, 6600 miles on it. Has not been ridden, or started that I know of, for about 4 years. Been sitting in my dad's garage on concrete floor.
Anyway, he wanted it gone so I am the new owner. Going to drain all fluids, gas, etc.
I pulled the dipstick to check it before draining and there was nothing on the stick. Weird but OK maybe it was low when it went into hibernation.
Pulled the drain and nothing......maybe 3 tablespoons all together.
Called dad to ask why there is no oil in the bike. Did he drain it and forget to fill it? He says he never drained it and would have not filled it back up if he did. Too dangerous in case someone came along and started it for some stupid reason, or there was a fire and had to get it away from house, etc.
So either dad is senile or what? Didn't leak out. Not a drop on the ground over those years of sitting.
I am puzzle and uneasy.
Here is what I did:
Took and 15in piece of welding cable and fished up the drain port thinking there was some sort of obstruction. Nothing that I could find.
Took of oil filter to change it too and got a TINY amount of oil out of the port there dribbling onto the motor. Few drops.
Left drain plug out and started pouring into the oil can. After about 1/2 qt. it started draining through and out the drain. Put plug back in.
My dad is not senile and a pretty smart guy. I cannot see him forgetting that he drained out the oil. Also, cannot see him not refilling it if he did.
Weird story
Here is what I did:
Weird story
I will look for the drain plug.
SO i was thinking that maybe dad WAS senile so I added about 3 qts of oil into it to the bottom of the stick. Was going to wait till I fired it up and filled the new filter and then add from there.
What is the best way to procede from here? It seems that I now have too much oil in there.
Received 14,174 Likes
Your missing oil is in the crankcase ( the bottom of the engine) go ahead and start your engine ( no more than 1 min) don't rev the throttle have a large pan to hold a gal under the engine vent tube , the missing oil will blow out the tube and some will return to the oil tank that is going to be over filled with what you filled with new oil and the oil in the tank will have lots of air in it so let it settle for a couple of hours and do it again till air stops in the tank
perki48 (12-18-2016)
Really sucks cause I think I just wasted 3 qts of Mobil 1 V Twin oil at $12 qt
Just making sure you read where I thought my dad was senile and drained out the oil so I added about 3qts in the can. So that would leave me with 3qt PLUS whatever is living in the case for the last few years. If I start it up and let it run for a minute of so, would that cause any damage, or spewing out of the filler plug making a MESS, to anything.
