4 1/2 in. Swept Back Risers For 2017 Slim
2015 slim with the pullback risers
So I understand that my situation doesn't fit the bill that you're requesting...But I can give some insight. My break line needed an extension installed. Since my clutch is only cable actuated, it only required an adjustment. I had the dealer do the install since the ABS needs a dealer computer-tool to run the break bleed procedure...Kinda criminal if you ask me. With that being said, I would probably guess the same requirement would be called for your hydraulic clutch lines.
are these the ones you're looking at? I installed them on my 99 fatboy no problem BUT I have a longer brake line on my bike. I lowered the brake caliper with an adapter bracket when I installed a newer style caliper, so there wasn't much extra line on mine. the brake line is easy to change if you don't have ABS. I've never worked with the HD ABS system but I hear it's a paint to bleed the lines.
have had them on my 2014since new and love them for same reasons you stated. Made me consider switchung to the street slammers. Have them in hand. Just too busy for a swap just yet.
