Fatboy-widest tire on stock set up?
Old 11-29-2005, 11:10 AM
rgm's Avatar
rgm
rgm is offline
Default Fatboy-widest tire on stock set up?
On the 2004 Fatboy, what is the widest tire and rim that can be put on without fender mods? Will a 180 or 200 fit?
Old 11-29-2005, 11:36 AM
MegaHDman's Avatar
MegaHDman
MegaHDman is offline
Default RE: Fatboy-widest tire on stock set up?
ORIGINAL: rgm
A Metzeler 160 is as wide as you can go. Its about 1/8" wider than your stock Dunlop 150
Old 01-15-2007, 02:48 AM
ScReaMnEagLE22's Avatar
ScReaMnEagLE22
ScReaMnEagLE22 is offline
is anyone running this particular setup or anything wider than the stock 150 ??
Old 01-15-2007, 10:51 AM
Babs's Avatar
Babs
Babs is offline
I'm interested as well.. Considering Metzlers the next tire change.. if I can ever clock enough miles to get there.
Old 01-15-2007, 02:19 PM
RandyM1911's Avatar
RandyM1911
RandyM1911 is offline
Heartland Biker claims to have a 180 that doesn't require any mods to the bike. I can't vouch for them but it's what they claim. Good luck.
http://www.heartlandbiker.com/Heartland_USA_Catalog.pdf
Here's a pic:
[IMG]local://upfiles/18158/11AE58B26F2141559895B9FC279E4178.jpg[/IMG]
Old 01-15-2007, 05:41 PM
ALsHDs's Avatar
ALsHDs
ALsHDs is offline
Using the Heartland Kit you will have to cut off the fender mounts/horns from the frame.The stock mounts are to close together for a 180mm tire on a "standard" softail frame. Check out the "FAT TIRE THREAD"
Old 01-15-2007, 05:46 PM
anubisss's Avatar
anubisss
anubisss is offline
The guy who owns heartland biker is a cool dude. I had a friend who used to work for him. Their stuff ain't cheap, just thought I would say...
Old 01-15-2007, 06:18 PM
Babs's Avatar
Babs
Babs is offline
I get the impression, given the tight tolerances in the stock fender, swingarm, pulley, brake and wheel that the Metzler 160 is pretty much it.. without any mods.
Old 01-15-2007, 09:44 PM
RandyM1911's Avatar
RandyM1911
ORIGINAL: ALsHDs
I know, I know, that's certainly what the pics show but they claim otherwise. Here's an ad for their 200 kit from the November issue of AIM.
Guess somebody needs to call and make a direct inquiry...
Old 01-15-2007, 09:56 PM
chester1957's Avatar
chester1957
chester1957 is offline
Heartland web site has 180mm for 2000 and up STail with their fender, seat, struts and wheel. 200mm would have to include swing arm.
Quick Reply: Fatboy-widest tire on stock set up?
