I think it all depends on the bags you use. If your bags do not have back supports, go with Easy Brackets or Ghost Brackets. If your bags have supports like the Harley bags go with Barebacks.
Thanks much- I already have the mounts for a detachable backrest so thought I might be able to use them for the Easy Brackets. I haven't purchased the easy brackets yet so wanted to check around to see how people liked them. Jack
Nice bike! The bag bracket looks like the ones I have seen in JP cycle. Is that where you purchased them and I assume they work pretty well for the throw over bags. I actually have some throw over bags that I was going to attach with the easy brackets but If I could use a bracket like yours it would be much cheaper and work just as well. I too do not want to relocate and I ride alone so I don't care if they bags are throw over. Are your bags pretty stable with that kind of single bracket. Thanks for the feedback. Jack
I was going to use the easy brackets but you have to relocate the turn light. These areDrag Specialtiesfor a 84-99 fxst part number DS110848. I got these because they stick out the same on each side. because they used a 200mm tire they are perfect. If you look at my link you will see the very large bagsI got and they ride great. I added the pinion seat when i used then to not only hold then on but more places to put things such as a passenger.
