I've got a chrome 4 piston frontPM caliper coming from fleabay, but the seller didn't have the banjo bolt. Will the stock HD banjo bolt work? If not does anyone know what sizethe PM caliper uses? It's the left side front for 2000+ softails. Part # 0053-2919
Hi Mojo, the stock bolt will fit ok but can be to long some times, you have to shave a bit off if thats the case! If you have time get a bolt from PM in the post!
According to the PM brake technical support PDF (which you can get from the PM website) - your banjo bolt is 3/8 x 24 PM part # 0084-2001. I would double check all that just to be safe.
