Banjo bolt at front caliper
Old Mar 30, 2013 | 12:36 PM
fergml's Avatar
fergml
Default Banjo bolt at front caliper
What diameter is the stock banjo bolt up at the front caliper on a Slim?
I bought a 6 piston Performance Machine front caliper and the banjo bolt in that caliper is 8MM at the point where the hole is (above the threads).
Before I pull off the stock brake line to make the swap, I'd like to know if the stock banjo bolt is same diameter or if I will need a whole new brake line to fit the 8MM bolt.
edit... according to the parts manual, the stock banjo bolt is part # 41747-82A. But of course does not list sizes/dimensions.
Old Mar 30, 2013 | 02:14 PM
Misbehaven's Avatar
Misbehaven
I believe it should be 7/16.
Old Mar 30, 2013 | 02:45 PM
chap!'s Avatar
chap!
I'd say they all use a standard size fitment, as there sold as a bolt on product.
I changed my calipers, front & rear to performance machine but at the same time changed to braided lines as well, so's to get the best from the calipers. I'd advise if you can, go with braided lines at the same time, one hell of a difference, more braking power & more feel.
Old Mar 30, 2013 | 06:39 PM
fergml's Avatar
fergml
Thought about new lines... But will wait until I change the bars. Glad to know the braided are the way to go.
KyleSterling
Apr 20, 2025 07:40 PM
Jpatterson317
Feb 27, 2017 08:31 AM
SmittyFXDL
Apr 18, 2016 09:25 PM
Reaper_ggy
Sep 18, 2011 07:52 AM
Lone Watie
Feb 18, 2008 12:35 PM
