Flstc front hub cap
03-12-2008, 07:06 PM
Flstc front hub cap
What parts are required to remove the dog bowl hub cap on the FLSTC?
Is there a smaller chrome piece that will replace it?
Thanks,
Wayne
2002 FLSTC
03-12-2008, 11:02 PM
RE: Flstc front hub cap
I removed mine a while back and just changed the wheel spacers. I have heard they need to be changed when the hub cap is removed, but I'm not so sure about that. The factory spacers appear to be the same size as the chrome ones I purchased. The only reason I changed the spacers was I wanted chrome ones.
03-12-2008, 11:11 PM
Dog bowl to some
baby moon to others
but the spacers will do the trick.
chappy
Quote:
ORIGINAL: WHarris
Thanks,
Wayne
2002 FLSTC
03-13-2008, 10:00 AM
You don't need anything. All you have to do is take the hub cap off, remove the ring clip on the inside of the hub which will release your stock wheel spacer. Put the spacer back on and your done. Just took mine off when I installed white walls.
03-13-2008, 02:00 PM
Thanks, guys
You are correct about the baby moon, chappy.
Just like the look of the laced wheel.
03-13-2008, 04:39 PM
Yup, Harleys are kind of like Burger King.
You can have a Harley and still have it your way.
chappy
Quote:
ORIGINAL: WHarris
Thanks, guys
Hey Man
06-10-2019 03:31 AM
DCM
07-05-2015 06:29 PM
ejvette
11-07-2011 06:55 AM
Reino_79
09-12-2010 03:24 PM
FLSTC2010
04-28-2010 08:37 PM
axel ,
axle ,
cap ,
caps ,
davidson ,
flstc ,
front ,
harley ,
hub ,
motorcycle ,
removing ,
slotted ,
spacer ,
spacers ,
wheel
