Deuce people, need your help again - cables
Well, we have the wife's Wild1 low profile pullback drags on her Deuce. The bars look great but I'm struggling with the cables a little bit. Pics are of the current setup.
Internally ran control wires - done and looks good. Very clean.
SS brake line routed through center hole and down. Again, very clean.
The clutch and idle/throttle cables are where I'm looking for some suggestions. I know a few of you have these bars on your Deuce. I am soliciting comments, lessons learned, etc.
Clutch, Idle, and throttle cables are currently stock length. The idle/throttle cables are binding up because of the bend created by the new bar shape. You can see from the pics how the clutch cable is routed.
Here's my dilemma: This is the wife's primary scoot so I want it to be perfect. I also want it to look good.
My intent is to get the clutch cable routed better. Best case I want it through the center hole in the trees but I am worried about hard lever pull from the bends required to get it routed that way.
I also need to do something with the idle/throttle cables. I have a set of +6 SS cables from another project that I was thinking I could route inside the right fork tube. It looks like the cables won't bind up that way and +6 looks like enough play to ensure full operation of the bars.
Ideas? Suggestions? Thanks in advance!
[IMG]local://upfiles/5927/0FCAF63BEADF485B86B6A205238C59CD.jpg[/IMG]
[IMG]local://upfiles/5927/D38BABFFE446442DAA9A4097F1E195B2.jpg[/IMG]
[IMG]local://upfiles/5927/14A02E3AA5C14BD4B0ECCA33FE335485.jpg[/IMG]
[IMG]local://upfiles/5927/5C163017A8CC4CBD904E7EAA3AD665BE.jpg[/IMG]
