New Speedometer / with tach??
Old 04-01-2008, 09:26 AM
whylee's Avatar
whylee
whylee is offline
Default New Speedometer / with tach??
I have been looking at the Harley catalog and they have some cool speedometers, the one I like is a speedometer almost like the one on my X Bones but it has a Tach also. It states that is a plug in. Im just wondering how you hook the tach up, im sure its not just a plug in if my bike does not have a tach now.
How is it hooking up a tach like this?
Old 04-01-2008, 10:08 AM
SCJE8's Avatar
SCJE8
SCJE8 is offline
Default RE: New Speedometer / with tach??
Hey whylee...
It should just be a 'plug and play' setup like my 2007 Fat Boy. Just remove the console nut and turn the console over and remove the old speedometer and replace it with the new speedo/tach unit. The wiring for my tach was already there. Real simple...just make sure that you put a towel or something over your tank to prevent mishaps! You'll only get a few extra inches of cable to move around with but itis plenty to swapout speedo units.
Good luck...
Steve
Old 04-01-2008, 10:14 AM
Mike NY's Avatar
Mike NY
Mike NY is offline
I heard the Odometer reading stays on all the time on the Combo's.. Is that true?
Mike
NY
Old 04-01-2008, 10:32 AM
In Memoriam Citoriplus's Avatar
In Memoriam Citoriplus is offline
May our Moderator Rest in Peace
You don't need a special line for the tach. The speedo hook up cable has a built in serialdata line that it uses for other functions like the check engine, oil pressure, and security light. Thetachuses the same data link for its info.
Old 04-01-2008, 10:46 AM
SCJE8's Avatar
SCJE8
SCJE8 is offline
Mike NY...
That is correct...the odometer readout stays on all the time on the replacement units. Don't know why they were designed that way, but theydo.
Steve
Old 04-01-2008, 10:53 AM
trafficjams's Avatar
trafficjams
trafficjams is offline
ORIGINAL: SCJE8
Mike NY...
Steve
i'm also curious about this unit...
i'm assuming you can still toggle between the different functions? trip meter, clock... etc?
Old 04-01-2008, 11:00 AM
jeeplite's Avatar
jeeplite
jeeplite is offline
For what ever reason you lose the clock, the total mileage is always shown but you still have a/b settings. I set one for tank mileage and the other for service intervals.
Old 04-01-2008, 11:07 AM
SCJE8's Avatar
SCJE8
SCJE8 is offline
jeeplite is correct trafficjams...
I only have Odometer, 'A' Trip and 'B' Trip...I swapped out at 25 miles and don't remember if I had a clock or not!
I purchased the Speedo/Tach unit from Zanotti and they set my mileage to match my OEM Speedo.
Steve
Old 04-01-2008, 01:46 PM
whylee's Avatar
whylee
whylee is offline
Cool, thanks for the replies.
Old 04-01-2008, 02:02 PM
Sarge4life's Avatar
Sarge4life
Sarge4life is offline
Steve,
I'm kinda curious about one of these as well. How much was it from Zanotti's?
Quick Reply: New Speedometer / with tach??
