rocker horn
RE: rocker horn
flyburch,
I certainly did. I just used it for the first time yesterday and it's very lame. If Gib could conjure up another specialty bracket, we might get the H-D premium air horn to fit. Maybe we could convince him to quit his day job and work full time as a Rocker consultant.
RE: rocker horn
I understand - sometimes a happy medium is just fine.
If we had a bracket to be able to convert the non-standard Rocker horn mounting to a standard one, we would then have the option of using anything from a standard horn to an air horn. They are all about the same size and use the same standard connection. Unfortunately, the Rocker horn connection is different.
RE: rocker horn
ORIGINAL: MartyF
flyburch,
flyburch,
RE: rocker horn
ORIGINAL: flyburch
anyone change the horn it sounds like a vespas horn. and not very loud anyone else notice that
RE: rocker horn
Some possible solutions
Does anyone know what the vrod horn sounds like? I modified the existing rocker bracket and covered my rocker horn with a vrod horn cover - using part of the vrod mount(about $3.95). If there is room for the cover should be able to use the horn.
On a previous thread someone mentioned using a NAPA horn, they even gave the part numbers. If I locate the thread I will post the part numbers.
[IMG]local://upfiles/55918/8AF24D652DD04F1484391C5FA871524D.jpg[/IMG]
RE: rocker horn
Don't know if this will work on the Rocker:
NAPA carries a replacement horn 730-1056 rated at 420 Hz and 132 db made for them by FIAMM. It appears to be the "Freeway Blaster". About $13 - $15 at your local NAPA store.
It fits underneath the HD factory cowbell and hooks up with existing wiring.
