Shock Adjustment
Shock Adjustment
I need a little advice guys..... Should I adjust the suspension for my fat ***?
I have a 2008 Fatboy. I am 6'2" and 325lbs. My wife is 150lbs. 90% of the time I ride with her on the back. It seems to bottom out every now and then (surprise). I was just wondering if there is any adjustments that I should do to the rear shock to compensate for the added weight. Thanks guys.
RE: Shock Adjustment
This link was very helpful when I adjusted shocks on my softail. See preload shocks.
http://fatbillscustoms.com/
It is not that big a difference in ride from all the way soft, to all the way firm. I have switched my shocks both ways twice and could hardly tell the difference. It will just keep the rear from bottoming when you have a passenger. I always set my shocks on my other bikes (not Harleys) to the firmest settings for better handling.
Tom
Tom
You may have to use a heat gun to loosen the loctite.
Harley ships their Softails with the shocks set at the softest setting.
1) paint a small fwd/aft white stripe on the bottom of each shock. This will let you count how many turns you do to the shocks and better allow you to keep both shocks adjusted the same.
2) brake the retention nuts loose and back them off
3) turn each shock body with the spanner wrench all the way to the firmest setting, this will be a little more then 3 full turns, then back them off just a bit so they wont be jammed in place.
4) tighten the retention nuts just a bit past snug. Don't put any loctite on them.
This will give you a comparison between the full soft and full firm settings. If this seems too firm then adjust the shocks back until you like the setting.
I adjust mine while the bike is on the jiffy stand using a spanner and an open end wrench, that I cut down to about 5" long.
Tom
