Front end wobble
Front end wobble
06 FXSTSI, 13K on the clock. New tire. I have noticed that when at speed when I let go of the handle bars, the front end starts to shake/wobble. Very slowly at first and then more and more. Nothing uncontrolable, but it is still there. As long as I am holding the handlebars, no problem, but when I let go it slowly develops a wobble. Any input appreciated...........balabce, bent rim, bearings????
RE: Front end wobble
I have had this on more then one bike and it has always turned out to be uneven tread on the front tire. I would look at my back tire and tire pressure in both tires. also look at the alignment of the rear wheel. My old man told me to look at the neck bearings on my heritage when I had this problem as well. On that bike it turned out to be bad alignment of the rear causing uneven tread on the front which caused the wobble. \\; Hope I helped.
The tires have 5k on them and look really good. I checked the rear tire alignment at the shop before I rode off to make sure it was aligned right.
I am going to retorque the neck bearings this weekend and see if that helps. Thanks to all that supplied input for my questions......
