HERITAGE SADDLE BAG MOUNTS BREAKING
Old 08-04-2008, 10:02 AM
R.E.LEE's Avatar
R.E.LEE
R.E.LEE is offline
6th Gear
Default HERITAGE SADDLE BAG MOUNTS BREAKING
THE LOWER RUBBER MOUNTS HAVE BROKEN ON MY HERITAGE TWICE NOW.&nbsp\\; ANYONE USED RIGID TYPE REPLACEMENTS?&nbsp\\; ANY SUGGESTIONS?
&nbsp\\;
&nbsp\\;
Old 08-04-2008, 10:47 AM
PWHOG's Avatar
PWHOG
PWHOG is offline
Default RE: HERITAGE SADDLE BAG MOUNTS BREAKING
fit the passenger foot boards and this makes the bag mounts rigid no problem.
Old 08-04-2008, 03:09 PM
CrimsonThunder's Avatar
CrimsonThunder
CrimsonThunder is offline
&lt\\;-same prob.&nbsp\\; Do you know a part number for that rubber bushing?&nbsp\\; Did you dealer cover it under warranty?
Old 08-04-2008, 05:40 PM
BIG Y 2014's Avatar
BIG Y 2014
BIG Y 2014 is offline
I Broke my rubber bushing removing the saddlebag i think if you lossen the nuts inside the bag first thenlossen up the nut holding the bushing this would not have happend. the part # is90524-01 hc- mount rubber $3.50 each
Old 08-04-2008, 06:18 PM
softailjim07's Avatar
softailjim07
softailjim07 is offline
i had to replace mine. for the lack of a hasle i did not even try to get them warrantied. your bike would be tied up for 2 days over 6dollars worth of parts.
Old 02-23-2011, 07:01 PM
sambeak's Avatar
sambeak
sambeak is offline
4th Gear
Can anyone help me with the part no's for the rubbers - Heritage Softail 2008
Thanks heeps
Old 02-23-2011, 08:25 PM
sambeak's Avatar
sambeak
sambeak is offline
4th Gear
no worries I found it in an earlier note
Sam
Old 02-23-2011, 08:31 PM
Gman in NC's Avatar
Gman in NC
Gman in NC is offline
The nuts are a type that won't fall off. Don't tighten them much when you put them on. I had the same problem. Mine broke the first time I tried to take the bags off. Not expensive, just a PIA.
Old 02-23-2011, 09:02 PM
arcticrider's Avatar
arcticrider
arcticrider is offline
wow!!! I had the same thing happen to me yesterday. I thought I would remove the bags so I could do a better job cleaning the bike. Didn't take much of a turn on the wrench to break the mount.
Old 02-23-2011, 09:40 PM
hdgzr's Avatar
hdgzr
hdgzr is online now
Received 1,874 Likes on 596 Posts
I just bought some extras, they're cheap. Since then, I've cut a piece of all-thread the same length as the rubber mount, and use a spacer equal to the thickness of the rubber part. Use an acorn nut on the outside. Not fancy but it works.
Quick Reply: HERITAGE SADDLE BAG MOUNTS BREAKING
