Fuel Management system
I've had V&H True Dual on for some time now and honestly the bike has been running fine. Much said here about adding a fuel management system (like Fuel Pak) and putting on a heavy air breather (like Big Sucker). I'm wondering what I would actually notice the difference to be if I was do this?
I put a set of slip-on's, SE air cleaner kit and a FuelPak on my '07 Heritage. It did improve the performance some, but not "holy smoke what a big difference". What it did do was cool the thing down, out of the box it was running about as lean as HD could get it and still have it run. I lost about 5 mpg on fuel milage, but this is to be expected because the FuelPak richen's up the fuel mixture. The bike runs flawlessly with the FuelPak. I'm happy.
Paul in Colorado
Paul in Colorado
I don't have an air breather kit on my Fat Boy yet, but I have installed a set of SE slip-ons. I probably could have done without any fuel management device, but I decided to give the XiEDs a chance. I haven't ridden very far on them yet, but so far I like what I'm seeing; the bike runs cooler and the mid-range power feels better.
You should be able to get a round cover over that, I believe that there are a number of guys running that setup. I have one on my bike, but I have a different filter setup than the big sucker.
One thing you want to watch out for when you get the round cover is that there are two differnt versions of it. Both are exactly the same size and should fit just fine, but one has a notch in the top to accomodate the choke (I think) on carbed bikes. But with the EFI you have its not needed and detracts from the look.
Thanks Citoriplus. Good info. I wondered about the HD cover because it has a screw in the middle and the Arlen Ness one didn't.
mile high king
06-01-2008 11:22 AM
